Multifunction DAQ
DAQmx- create channel- no channels found
i am new to labview. So maybe my question is easy...
I want to generate a signal. That's why i am using the DAQmx-create channel.vi . I i created a control to chose the channel, where the signal is generated. But no channels are found.
i am using PXI 5412 and my device is visible in MAX. So i don't know what is the problem. Can anyone help me?
Ratta
(4,334 Views)
Accepted by ratta
The 5412 is an Arbitrary Waveform Generator. It does not use DAQmx. It uses NI-FGEN.
GCentral
(4,329 Views)
Thank you very much! i didn't think about it...
(4,318 Views)
