DAQmx- create channel- no channels found
i am new to labview. So maybe my question is easy...
I want to generate a signal. That's why i am using the DAQmx-create channel.vi . I i created a control to chose the channel, where the signal is generated. But no channels are found.
i am using PXI 5412 and my device is visible in MAX. So i don't know what is the problem. Can anyone help me?
Ratta
(4,348 Views)
Accepted by topic author ratta
The 5412 is an Arbitrary Waveform Generator. It does not use DAQmx. It uses NI-FGEN.
GCentral
(4,343 Views)
Thank you very much! i didn't think about it...
(4,332 Views)
