DAQmx install fails on openSuSE 11.1
I've been test driving openSuSE 11.1 today, and I discovered that DAQmx will not install properly. It looks in /lib/modules/2.6.xx/source for the headers instead of /lib/modules/2.6.xx/build. openSuSE installs the headers to build and the kernel source packages to source.
John
(3,937 Views)
After a successful run of updateNIDrivers, none of the modules will load, dmesg shows this:
Symbol init_mm is marked as UNUSED, however this module is using it.
This symbol will go away in the future.
Please evalute if this is the right api to use and if it really is, submit a report the linux kernel mailinglist together with submitting your code for inclusion.
nipalk: no symbol version for nNIKAL100_unregisterPCIDriver
nipalk: Unknown symbol nNIKAL100_unregisterPCIDriver
nipalk: no symbol version for nNIKAL100_waitForSingleUseEventTimeout
nipalk: Unknown symbol nNIKAL100_waitForSingleUseEventTimeout
and so on....
(3,934 Views)
kernel is 2.6.27.21-0.1-default
(3,933 Views)
Upon further investigation, it appears that CONFIG_MODVERSIONS was selected in the openSuSE 11.1 kernel. This feature was introduced at kernel version 2.6.26. I don't know at the moment what is required to build the modules with versions. modprobe --force will allow them to load though. I'll do some more research and report back.
(3,910 Views)
Accepted by topic author ninevoltz
I never figured out how to version the modules, so I just rebuilt the kernel with module versioning turned off. Now it works fine.
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
(3,904 Views)
Hey ninevoltz,
I'm glad you figured out a work around for the modversions issues.  I've been working on solving the problem for NI-KAL 1.10, but it is proving to be difficult so I can't make any guarentees.  I currently have it working after you run updateNIDrivers, but a clean install doesn't work.
The comment about the kernel headers in /lib/modules/$(uname-r)/build/ instead of source/ is semi accurate.  The kernel-source package on openSUSE installs unconfigured kernel source.  If you configure the source it will work fine:
cd /usr/src/linux
make cloneconfig
make modules_prepare
Also since I know you have done a lot of work in the past with some of our Linux products you may want to join our Linux Users Group.   You can post tutorials, ask questions, etc..
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(3,898 Views)
