Multifunction DAQ
DAQmx linear ramping AO voltage
I am trying to create a linear AO voltage using the DAQmx functions to control xy galvo mirrors. How can I create a linear ramping voltage where I have control over slope and amplitude of the votage ramp?
(4,175 Views)
I would use the Ramp Pattern function.  Then just write the values to the Analog Output.
GCentral
(4,171 Views)
Thanks for the reply!
I have tried using this function and it does work, however, is there a way to control the amount of samples that it uses? I would like a smoother ramping function than it seems i can get with this.
(4,164 Views)
It is a polymorphic VI.  You can choose to have it create the ramp based on the number of samples in the ramp or by a delta.
GCentral
(4,161 Views)
