DAQmx property to identify Device type
Hello is there a Device DAQmx propery that would return what is the primary measurement type for given device?
Meaning for instance:
9201 would return Analog
9203=Current
9211=Thermocouple
Thanks!
LV 2011, Win7
(4,309 Views)
Accepted by topic author ceties
Hey Ceties,
  What you can do is use the DAQmx Device Property node with "Product Type" property. This will give you in string the type, like NI 9211. With this info you should create an own table with corresponding string values(like "Thermocouple") and chose the right one from the array. Unfortunatelly there is no property tha will give you directly this information.
Please let me know if you need anything else!
David Varga
NIH
(4,291 Views)
Thanks David,
I was thinking of that already but that would mean that I would have to update such a table regularly which is not really handy. It would be nice to have such a property for the future. I think I saw somewhere a discussion about future DAQmx property nodes. This would be the right "candidate".
Cheers
LV 2011, Win7
(4,288 Views)
This will get you the type, but not exactly what you wanted.
(4,050 Views)
