Mac NI USB-6009 installation
Hi there.
Me and my teacher are trying to install a NI USB-6009 in a snow leopard Max OS. We will use it in LabView2009®. At this moment we already installed the drivers and the application "lsdaq" already detects it: "NI USB-6009: "Dev1"    (USB0::0x3923::0x717B::01183702::RAW)"
Moreover, when we click "NI DAQmx base task configuration", in the LabView2009®, we can actually create a task with the device "NI USB-6009: "Dev1"            (USB0::0x3923::0x717B::01183702::RAW)". However, after creating a task, like, for instance, "analog input", we can't see the task in the LabView in the button: (Measurement I/O -> DAQmx base - Data acquisition ->) "DAQmx Task Name Constant".
Thank you very much for your time,
littlepig
(5,992 Views)
Hi Littlepig!
This is expected behaviour because you are working on the DAQmx Base version of the driver. You can try to introduce the name of your task directly on the costant or follow the directions on the following link:
http://digital.ni.com/public.nsf/allkb/BEC50958B46CF6B98625707C00504159?OpenDocument
I hope this info helps.
Have a great day!!!
(5,977 Views)
After I tried that:
Error -200428 occurred at an unidentified location
Possible reason(s):
Value passed to the Task/Channels In control is invalid.
after i created a task named "test", with an "analog input", and, in the LabView, made a task/channel, write "test" in it, and join it to a DAmxbase start task.
(5,962 Views)
Hi Oswald
I was not authorized to open the document you have referenced can you help me?
(5,102 Views)
Hi littlepig,
Were you able to measure a voltage with your NI USB-6009 and display it in LabVIEW?
(5,101 Views)
This thread is >2 years old and neither of the participants has been on the Forums for months or years.
Please start a new thread with a complete description of the problem you are having, what you have tried and what is not working, including any errors you may be getting.
Lynn
(5,094 Views)
Hi Rob,
John is right. You should create a new topic.
Just in case, I think this is the needed document:
[9/8/25 broken link removed; link no longer available]
regards
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
(5,084 Views)
