Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
DAQmx simulation signal
Re: DAQmx simulation signal
Dennis_Knutson
Knight of NI
03-17-2014
07:35 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Give up the DAQ Assistant and use the much more flexible DAQmx functions. A front panel channel control has the ability to select channels. You could also define the tasks in MAX where people can edit them.
1
Kudo
Message
11
of 12
(1,093 Views)
Reply
andcp360
Member
03-18-2014
08:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks, i will try do it!
0
Kudos
Message
12
of 12
(1,086 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
