DAQmx task name refer in CVI
Hi ALl,
I have a DLL created out of LabVIEW. This dll is used to generate a signal on DAQ card. Physical channel is selected at runtime. I want to access this function in LabWindows/CVI. The dll creates an object type LVRefNum. How do i initialize this variable and use it in CVI. Do I need to make an changes in LabVIEW to refers the task name and physical channel in CVI?
Pradeep
Message 1 of 1
(2,784 Views)
