NI 6229 Analog channel to generate current
I am using PXI-6229 to generate current values on analog output channel but i get the following error:
"Selected physical channel does not support the selected property. Either select a channel that supports the property or select a property that is supported by the selected channel"
I tried with all 4 analog output channels: ao0,ao1,ao2,ao3  but i got the same error with all. Also when i execute the NI examples at
"CVI\Samples\DAQmx\Analog Out\Generate Current\Cont Gen Curr Wfm-Int Clk"  location, I get the same error.
Kindly let me know the solution to it.
Priya.
(3,341 Views)
Accepted by topic author KSPriya
The 6229 analog outputs are voltage sources - not a constant current source.
(3,337 Views)
