---- Hello Morgois-
Can you give me a little more information about your application? What device are you using? How many samples are you generating? If you can possibly post your code as well, that also would be helpful.
Thanks!
gus....
I am generating a sine wave, using the 6251 board, and DAQmx. Specifically, I use the DAQmx Start Task and DAQmx Wait Until Done. I am generating it using the 2.8 MHz sampling frequency, so it auto-generates the number of samples. I try between 10 kHz and 120 kHz or so, and it only stops properly if the pulse is longer than 50 usec. If it's shorter, the rest of the program will run, but it will give the error "Error -200560 occurred at DAQmx Wait Until Done.vi" no matter how long the timeout is (-1 or a long time doesn't help). If the sine pulse is less than 50 usec, it works fine. 120 kHz I can do if I make the pulse long enough, but a single cycle at 120 kHz gives this error, for example.
