Multifunction DAQ
DAQmxCfgSampClkTiming external clock
I would like to how to use a external clock in the function DAQmxCfgSampClkTiming ?
I have a NI USB-6251.
First, I was using the internal clock with the line
DAQmxCfgSampClkTiming(MyTask, "" , MySampFrequency, DAQmx_Val_Rising, DAQmx_Val_ContSamps, NumberOfSamp);
DAQmxRegisterEveryNSamplesEvent (MyTask, DAQmx_Val_Acquired_Into_Buffer, NumberOfSamp, 0, EveryNSamplesCallback, NULL);
With a sampling frequency of MySampFrequency = 160kHz ;
Next,  I tried to use  an external clock :
DAQmxCfgSampClkTiming(MyTask, "/dev1/PFI0" , MySampFrequency, DAQmx_Val_Rising, DAQmx_Val_ContSamps, NumberOfSamp);
With a 500kHz clock on PFI0
So just changing from internal clock to external clock. Then I was testing the number of acquired samples to choose if I stop or continue. I was expecting that the needed time to acquire the samples would not change but it was much shorter. So I concluded that my sampling frequency was the parameter I entered in the first case. What should MySampFrequency be to get a sampling frequency of 160 kHz ?
Is it possible to use an external clock as a stability reference clock, to fix the drift of the internal clock ?
Thank you
Regards
(4,572 Views)
Accepted by banchilu
If you use an external source for the Sample Clock, set MySampFrequency to the maximum expected rate of that external clock. So if you use a 500kHz clock on PFI0, set 500kHz to MySampFrequency .
I was wondering what do you mean by telling "So I concluded that my sampling frequency was the parameter I entered in the first case" ?
The internal clock has a drift but this is enough accurate. However you can still use an external clock with a frequency that is perfeclty known.
Regards
(4,554 Views)
I just mean that when I use a internal clock, the sample rate is the sampling frequency but when I use an external clock, it is not. What happens if I put as sample rate parameter a smaller frequency than my external clock one ?
(4,547 Views)
Hi banchilu,
DAQmx uses the sample rate to determine the default AI convert clock rate and input buffer size. If your program sets the sample clock rate to be smaller than the external clock frequency, you may run into ADC overrun errors or FIFO overflow errors.
Brad
Brad Keryan
NI R&D
(4,540 Views)
Ok.Thank you
(4,538 Views)
