Multifunction DAQ
DAQmxCreateAOFuncGenChan - how to use?
I'm looking for a c(++) sample code which uses this function (DAQmxCreateAOFuncGenChan). Which devices are supported?
Thanks!
(4,762 Views)
Accepted by bestware
The  DAQmxCreateAOFuncGenChan is only supported on the Elvis II products. If you don't have one of those, you'll need to create a regular AOVoltage task and create your own buffer of data.
Hope this helps,
Andrew S.
(4,756 Views)
Thanks a lot, Andrew!
Couldn't find those information on any NI doc or site.
(4,748 Views)
