DAQpad-6016 and windows 7 64 bit or windows 10
Hi
Does DAQpad-6016 work only on windows 32 bit?
Regards
(3,056 Views)
Hi inzinierius
The DAQpad is not restricted to any OS.
Any restrictions you might encounter is due to your version of DAQmx.
i suggest looking at the readme file for your version of DAQmx.
regards
(3,007 Views)
The DAQPads, unfortunately, are restricted to 32-bit OSes only. See the "Devices Not Supported in NI-DAQmx on the 64-Bit Versions of Windows 10/8.1/7" section in the NI-DAQmx 18.1 Readme:
The following devices are supported in NI-DAQmx on the 32-bit versions of Windows 10/8.1/7. They are not supported on the 64-bit versions of Windows 10/8.1/7:
NI DAQPad-6016 for USB
(3,003 Views)
Thanks for the help
(2,993 Views)
