DAQpad 6020E not configured on WinNT
I am testing a device connected to DAQPad6020E. When I connect to a WindowsNT system, and run MAX, the device is not shown. Devices & interfaces -> create new, also does list the 6020E. The 'Device configured' light on the DAQPad lights up for a second after I switch it on and then turns off. What could the reason?
I want to switch the DAQpad6020E between a Windows NT and Windows XP system often. What is an easy way to do this?
(2,430 Views)
Rajis,
Unfortunately USB is not officially supported under Windows NT. Do you have any working USB devices on your NT system? Your problem may be one of USB/OS compatibility.
Here is a link to the online DAQ Troubleshooter page.
The DAQPad6020E is only supported under Traditional NI-DAQ running on operating systems that support USB devices (such as Windows 98, 2000, and XP). Please post back if you have any further questions or support issues.
Craig H.
(2,430 Views)
