using DAQ to supply voltage to a bridge?
I would like some guidance on developing a block diagram to supply voltage (AO?) to the excitation end of a bridge which I plan to read using the AI functions.
I would like to drive the bridge only when collecting data. I am not grasping how to do this in the block diagram. :kind of exasperated:
Thanks!
-aa
(2,778 Views)
Thank you for contacting National Instruments.
From what you have described, it sounds like you are trying to supply an excitation voltage to a bridge circuit, possibly as part of a strain gauge application.
If you are simply interested in supplying the bridge with a steady voltage using the analog output of your DAQ card, I have attached a small example VI that illustrates how to do this with DAQmx. There are also numerous examples included with LabVIEW that demonstrate how to perform various I/O functions using both DAQmx and Traditional DAQ. Just go to Help >> Find Examples, and with the browse tab selected, go to Hardware Input and Output.
You can incorporate this basic analog output structure into your code such that it only executes w
hen you begin collecting data. This can be done a number of ways, from data flow programming to using case structures.
I would also like to mention that if you are in fact driving a bridge as part of a strain gauge application, National Instruments provides hardware specifically designed for this kind of application.
I hope this helps! Let me know if you have further questions.
Matthew C
(2,778 Views)
Thank you very much, Matt. LabView 7 is a lot more complex that the older versions!
I will work with the VI you sent and keep working on this.
I am driving an LVDT position sensor, which I was assured by the sales rep could be done with the combination of PCI-6036E and LV7. Actually, it is not going that badly. I am mostly hanging up on the little information feeders for all of the controls.
-aa
(2,778 Views)
