DC Current measurement by USB 6341
Using USB 6341 DAQ box can i measure the DC current?
(2,241 Views)
With some external circuitry, you sure can.  You will need some kind of current shunt resistor (something really small, such as 0.01 to 1 Ohm).  I would also get a high-side current sense amplifier (such as a TSC103IPT) to turn the measurement into a single ended signal and into a voltage range more suitable for the DAQ.
(2,224 Views)
Thank you.
(2,156 Views)
