Compatibility issue: PCI 6229 + NI-DAQmx 15.5.1 + LV2012 + Windows 10 64bit does not work
I have used PCI 6229 + NI-DAQmx 15.5.1 + LV2012 + Windows 7 64bit for several years now. Having switched to Windows 10 and having read all related information provided on the NI website PCI 6229 + NI-DAQmx 15.5.1 + LV2012 + Windows 10 64bit is compatible. However, it does not work. What is wrong?
(2,187 Views)
It would be useful for the community to understand better how are you noticing this incompatibility. Is the card detected in the Device Manager? Does it show up in NI MAX? Do you get an error message or crash of some sort?
Additionally, it is worth pointing our that LabVIEW 2012 was not released for Windows 10, per its readme.
(2,101 Views)
