04-08-2008 09:53 AM
04-09-2008 05:05 AM
04-09-2008 06:26 AM
Hi Ian,
Many thanks for immediate reply and suggestions with the motor ON/OFF VI.
Thanks for correcting it, as now I got the idea, where I needed correction.
About the motor (which I want to control) and its application:
Currently motor is run by proper drive which powers it, but eventually we want to get rid of that drive so that we can control the motor independent of drive, solely on PC and LabVIEW.
Specifications of motor are:
Voltage: 220/240V
Current: 1.38/0.8 Amp
Frequency: 50Hz
Phases: 3
RPM: 3000
The motor is being used for generating vibrations for medical application,
therefore we need fine control over motor speed and its switching (ON/OFF).
Please guide me through the best possible way for it (controlling the motor).
Thanks and regards.
Amit
04-09-2008 10:02 AM - edited 04-09-2008 10:07 AM
04-09-2008 10:11 AM
Hi Ian,
Many thanks, I shall wait.
Thanks.
Amit
04-09-2008 10:21 AM
04-09-2008 10:43 AM
Hi Ian,
I beg your pardon, I am not quite sure whether the motor is AC or DC,
I apologies for the heading of the posts, if it is wrong. The specifications which I mentioned are correct and manufacturer is VIBTECH, serial number being: 040261596.
The motor should be AC as the drive which I am using for it is AC drive for running 3-phase induction motor.
Does this gives you enhough/correct information to decide whether motor is AC or DC?
Thanks and regards.
Amit
04-09-2008 11:01 AM - edited 04-09-2008 11:10 AM
Hi Ian,
I am attaching data sheet of motor I am using, also attaching data sheet of controller/drive I am currently using to drive motor.
Thanks and regards.
Amit
http://www.vibtec.com/catalogue.htm
04-10-2008 03:22 AM
04-10-2008 04:00 AM
Hi Ian,
Thanks for information about all these interfacing. I suppose electronic interface is possible through controller drive (VSC) and SCB- 68 (NI) Board. And even if electronic interfacing is not possible on this drive, right now, we will try and buy the suitable one since we need to change the hardware according to interfacing requirements of LabVIEW. As using LabVIEW for controlling this and other parameters is our software plan.
Once I speak with my adviser on this issue of hardware interfacing, If I have any query then I shall post it immediately.
But, for the time being assuming that, we can control the motor electronically, could you please guide me through how I can precisely control the speed of the motor via LabVIEW programming.
Many thanks.
Thanks and regards.
Amit
