DC motor speed control
Hi Ian,
That is great, many thanks.
Thanks and regards.
Amit
Message 21 of 26
(1,827 Views)
Ian,
I need help in figuring out how to control my DC motor.  It is 1/4 HP @ 1725 RPM, 90V, 2.8A full scale.  I need around 200 in-lbs of torque for my application.  I have a SCXI-1124 and a motor controller.
-Scott
Message 22 of 26
(1,791 Views)
Hi Scott,
One of my colegues,the community or I will be more than willing to help you with your motor problem, but it would be a great help if you could copy your post into a new thread. This way one of our team can pick it up (as this thread is viewed as resolved on our system) and it makes it easier for members of the community to see your query and help you out aswell.
Best Regards,
Ian
Message 23 of 26
(1,785 Views)
can any expert out there help me in my project? im doing 750W AC motor rpm control using labview 8.5 and  im using USB NI 6008 DAQ..how can i interface the DAQ with the motor..and how to generate the PWM to control the motor RPM..how does the PWM signal related with the RPM? thanks
Message 24 of 26
(1,676 Views)
Hi I am trying to build a DUAL DC  MOTOR SPEED CONTROL using atmega38. I was told to use a PIC CONTROLLER but I found this arduino ,atmega328 easir to program. Can you plaese provide me with any information about this project as to how i should do it? It is to be used on a wheel chair for the disabled. Please let me know ASAP.
Thank you,
Harish
Message 25 of 26
(1,293 Views)
Harish,
1. You have posted to a thread more than 4 years old.  Many ot the particpants in that thread have not been on the Forums for several years.
2. Your question has very little (other than the title) to do with the discussion in that thread.
3. The Board is for questions about Multifunciton DAQ devices, primarily by NI. Your question mentions nothing about DAQ.
4. This Forum is to help people learn to use NI products, not to do all the work for them.
You might be better off finding an Arduino support Board for your request.
Lynn
Message 26 of 26
(1,287 Views)
