Multifunction DAQ
DIO Port 2 of a PCI 6229 seems not to work
I am planning to use a PCI-6229 for analog recording and digitally controlling the measurement equipment (electrophysiological recordings). It seems that the digital Port 2 of the device is not working (tested with the measurement and automation explorer). When I set Port 2 to Output and all bits on high, I can't measure anything on the output wires while the same procedure works fine for ports 0 and 1 (i.e. 5 V for high bits). Does this mean that port 2 is broken or is there some trick I have overlooked so far?
                                            Daniel Wustenberg
(2,751 Views)
Hi Daniel,
  I've contacted you directly - sounds like a broken board and we need to start a returns procedure away from the forums.
The service request number is in the subject line of the e-mail I sent you and the phone number is 01635 572410.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(2,735 Views)
