Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
DIsable CTR 0 OUT
DIsable CTR 0 OUT
Nicolas_l2001
12-12-2007
08:34 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm using a DAQ6024 E series PCMCIA DAQ card and using labview 8.2. I've a signal that is connected to both ctr 0 out and ai 1 (differential mode). The problem is that sometimes I've to read
0
Kudos
Message
1
of 2
(2,902 Views)
Reply
Re: DIsable CTR 0 OUT
demux
Active Participant
12-13-2007
02:46 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Greetings Nicolas,
You can find the answer in your
Second Post
Kind Regards,
Wouter
Kudos
Message
2
of 2
(2,893 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
