Data I/O Problem
Would like to know how to check AT-MIO-16DE-10 board for function for function.
(3,444 Views)
I'm not sure what 'for function for function' means but you have a test panel in MAX that you can run, assuming you have the correct driver installed.
(3,431 Views)
altecheco,
If you could give us some more detail on exactly what you are trying to do, it would help us give you some suggestions. Thanks!
Aaron W.
(3,408 Views)
