Data acquisition ( current measurement )
Hi ,
I am working on LabVIEW 2015 project, i have in my test specification a need of measuring of the output current of the product with an average of 10 ms time window, that means in 10 ms I should have an N simple  and there  average  ,
1- I created my task in NI max  , but i don't know which are the best configuration for this test  and how i can used with labview :
 2- i have 7 Ni chassis cDAQ-9184 with the same configuration ( Ni xnet +   Ni ni9227 )
 the software must be compatible with all the chassis without any modification in the Ni max   but  there is a difference of the address Mac  on those chassis ,  I tried to change  the name of address mac but it doesn't work correctly, have you an idea about this please,
Thank you ,
(2,728 Views)
You probably need to constantly read the data.  So I would use Continuous Sampling, 1kHz, 10 samples.  (10 Samples)/(1kHz) = 10ms of data.  You can then do a simple average on the read data.
MAC addresses are fixed my the Ethernet adapter.  What you care about are the IP addresses.
(2,684 Views)
