 Gourab12
			Gourab12
			03-17-2021 10:57 AM
In my project, I want to do the data acquisition with NI 9775 digitizer in a record mode at a 20Ms/s rate but I could not implement it in Labview program. In continuous mode, the sampling rate is 4Ms/s, and the working fine. It would be fine if someone helps me (with an example program) how to use the digitizer in a record mode.
With regards
Gourab
 Rnouna
			Rnouna
			10-07-2021 10:45 AM
Hey,
i will do the some. did you get it working. I do not found how to configure the DAQmx to recorde mode.
thanks
