Multifunction DAQ
Data representation in Traditional DAQ and DAQmx
Hi
I am using a NI-6013-PCI card, and used DAQ_Op and DAQ_Start to acquire data from the device (with gain set to 1), which have a CCD camera to acquire data.
I did migrated the application to DAQmx, it is working fine but the intensity of the graph plotted using the data is lower than the expected one.
While migrating the old code I replaced DAQ_Op by the logic given below
TaskHandle ulTaskHandle =  0;
DAQmxCreateTask("", &ulTaskHandle);
double dMaxVolt = 5.0;
double dMinVolt = -5.0;
DAQmxCreateAIVoltageChan(ulTaskHandle, "Dev1/ai0", "", DAQmx_Val_Cfg_Default, dMinVolt, dMaxVolt, DAQmx_Val_Volts, NULL);
/* This function handles various select signal combinations.
 * - Select_Signal(1, ND_PFI_2, ND_IN_CONVERT, ND_HIGH_TO_LOW)
 * - Select_Signal(1, ND_SCANCLK_LINE, ND_SCANCLK, ND_LOW_TO_HIGH)
RouteSignal();
DAQmxCfgSampClkTiming(ulTaskHandle, NULL, dSampleRate, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, ul64SamplePerChan);
DAQmxStartTask(ulTaskHandle);
/* Allocate memory for data acquisition. */
double* pDataBuf = new double[ulCount+1];
long lSamplesToRead     = (long)ulCount;
long lSampsPerChanRead  = 0;
DAQmxReadAnalogF64(ulTaskHandle, DAQmx_Val_Auto, DAQmx_Val_WaitInfinitely, DAQmx_Val_GroupByChannel, pDataBuf, lSamplesToRead, &lSampsPerChanRead, NULL);
if (ulCount != (unsigned long)lSampsPerChanRead)
else
    for (unsigned long ulIdx = 0; ulIdx < ulCount; ulIdx++)
        /* psBuffer is a short array.
         * Here I try to convert and copy the new buffer (double values)
         * to old buffer (short values)
         * I assume that old values will be in the range of millivolt.
         * To convert the volt values from current buffer to millivolt I am multiplying it by 1000
         * I don't know whether it is true/
        *(psBuffer+ulIdx) = static_cast<short>((*(pDataBuf+ulIdx)*1000));
I am not sure whether the conversion I did from new buffer to old buffer is true. Do I need to create a DAQmx_Val_FromCustomScale to get the same value as DAQ_Op returned?
Could you found any thing wrong with the logic? How can I get the same value as DAQ_Op returned from the double buffer returned by  DAQmxReadAnalogF64() Is there any other best mechanism available?
regards
Praveen.DA
(3,767 Views)
I called NI support team yesterday and made a post in the discussion forum, but I didn’t get any reply from NI! I am in a difficult situation!!!
I shall explain my problem once again.
I had an old application (VC++) using NIDAQ and it was using DAQ_Op(), with gain 1, to read data using the NI 6013 PCI card. Currently I migrated it to DAQmx. Below given code was used to replace the DAQ_Op() function.
I am facing problem due to the difference in data values acquired DAQ and DAQmx.
I connected the card (no device connected to the card) to my computer and called DAQ_Op() and DAQmx functions to read data. I got data as given below.
DAQ
3594
3602
3595
3610
3604
3597
3606
3596
3599
3606
DAQmx
0.563507
0.563049
0.563354
0.563660
0.563965
0.563965
0.563965
0.563660
0.564117
0.563812
From the data I found that DAQmx value is around 6500 times lower than that of DAQ.
1. What does this means?
2. Why the values are different?
In DAQ data is retrieved as a short integer value while in DAQmx it is it is retrieved as double precision float values.
1. I would like to know how above data is represented in DAQ and DAQmx?
2. Also can you specify the unit of the value returned in DAQ and DAQmx?
Regards
Praveen.DA
DAQmxCreateAIVoltageChan(ulTaskHandle, "Dev1/ai0", "", DAQmx_Val_Cfg_Default, 5.0, -5.0, DAQmx_Val_Volts, NULL);
/* Copy data in pDataBuf to short value buffer for further processing */
(3,726 Views)
If you want to read integer values with DAQmx, then why would you use the DAQmxReadAnalogF64 function? You just need to read the help file at Start>Programs>National Instruments>NI-DAQ to find the functions that return integer values. Both tradtional DAQ and DAQmx have separate functions for the type of data to be read. Use the correct one and your problem is solved.
(3,713 Views)
I found the reason for this bug.
I was using NI-6013-PCI card. and tried to read data using DAQmxReadAnalogDataf64() function.
From the specification of NI-6013-PCI card, I found thet the analog data input resolution is  16 bytes. So it should be read using a function that reads 16 bit data. DAQmxReadBinaryI16, DAQmxReadBinaryU16 or DAQmxReadRaw can be used in this regards.
So, you should refer the resulution of input data, from the specification of the DAQ device, before using a particular read function.
(3,674 Views)
Accepted by praveenda@gmail.com
The reason for your bug is that you apparently did not understand what the DAQ_Op function does. In the help for it, it clearly says that the data returned is I16. Your choice of F64 data was a clear conflict with how you had porgrammed the board in traditional DAQ. The resolution of the board does not really matter. The big difference is scaled and unscaled.
(3,665 Views)
Thank you for your support. I was able to fix the issue
(3,646 Views)
