12-20-2017 10:40 AM - edited 12-20-2017 10:43 AM
The snippet below is a sample code for acquiring Analog data with the bare minimum functions. No Sampling rate / clock source etc have been provided.
The HW used is a USB6212 which has a max sampling rate of 400kS/s.
DAQMX_Acquire.pngQuestion is : in this setup when the timed loop fires , how many samples will i get for each channel ... of course easy is to run and see for myself. But HW is not at hand and i have some issues reported from client on missed points in a contiguous sensor data.
12-21-2017 09:12 AM
OK i could improve the setup as below. Only one doubt is there ... i have wired the No Of Samples input to the "EdgeCount" input of the Timing Source function. Is this correct ( it works with this connection anyway )
