Default Settings for Digital Lines? USB-6009
Hi All,
I am using the digital lines on my USB-6009 to control normally-opened SSRs.  When I turn the system on, I'd like to have the digital lines on the USB-6009 automatically configure themselves to be digital output lines set in the "Low" position, so I don't switch on my SSRs until I give the command.  Is there a way to do this?
Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,397 Views)
Accepted by diarmaede
Can't set default states on 600x DAQs, unfortunately.
Have to do some engineering on the hardware side knowing the lines are pulled high when the DAQ is initialized; and if some combination of outputs produces a hazardous situation, you'll need to stop that from happening in hardware.  Good practice to do anyways.
Other option is to use an analog output, those can pump a little more current than the DO's and default at 1V which usually isn't enough to toggle SSRs.
(3,393 Views)
Thanks.  That makes sense.  I've used the analog channels in the past, but I wanted to "do it right" this time.  Maybe doing it right is the wrong way to do it in this case.
I'm going to transfer the whole setup to a CompactDAQ chassis as soon as my new NI toys come in.  I'll be using a 9401 DIO module for the digital lines.  Can I set that unit up to default to the conditions I require?  But, yes, I will make sure that the lines are automatically switched to the low position if when the system is set up.
Forbes Black
(3,390 Views)
