Delayed voltage measurement using a start from a TTL pulse (PCI-6251, NI-DAQmx)
What I need to do: acquire a voltage measurement after a certain delay (order of microseconds) when we observe a TTL pulse, lasting for around 1-100 microseconds. What options do I have for doing thins?
PS. If this problem is solved in some C code example, please point me to the right direction; I browsed through the NI-DAQmx examples, but didn't spot anything like this.
(3,863 Views)
Bump. 😞
(3,842 Views)
Accepted by topic author Hohum-hrm
Hi Hohum-hrm,
The DAQmx ANSI C example Analog In\Measure Voltage\Cont Acq-Ext Clk-Dig Start demonstrates how to use  DAQmxCfgDigEdgeStartTrig() to enable a digital start trigger. It also demonstrates continuous acquisition, external sample clock, and every N samples events; for a simpler starting point, look at Analog In\Measure Voltage\Acq-Int Clk-Anlg Start and try converting it to use digital instead of analog triggers.
However, this will start the acquisition exactly when the trigger occurs, not after a fixed delay. To add a fixed delay between the trigger and the start of the acquisition, use DAQmxSetStartTrigDelay() and DAQmxSetStartTrigDelayUnits(). The NI-DAQmx C Reference Help (which should be on the start menu under National Instruments >> NI-DAQ) lists the valid values for the units property.
Brad
Brad Keryan
NI R&D
(3,819 Views)
Many thanks,, I will inspect this further!
(3,795 Views)
