How do I turn voltage output of NI 9263 on and off using a timing circuit?
 LabView 8.6
cDAQ-9172
NI-9263
I used the simple fan control  - but can it be modified to turn on and off via a timing circuit instead of a button.
In other words for example 5 seconds on and 10 seconds off.
I would also like the timing to be adjustable.
(3,741 Views)
Accepted by topic author HelpMe9211
Hi Helpme9211,
Please try modifying as my attached screenshot.
Regards, Kate
(3,738 Views)
Hi Kate,
Thank you for answering Helpme9211's question, the code looks good for what he is trying to do.  I just wanted to point you (and any other readers) to our Developer Zone Community, which we have created to allow customers to post code to exchange with others.  The code in the screenshot that you have sent would be a perfect example for the Community should you decide to post it.
Here is a link to Frequently Asked Questions about the posting content in the Developer Zone Community.  Thanks again for taking the time to post here on the forums, it is always great to see LabVIEW users helping each other out.  The Community should take this one step further by allowing user-generated example code to be searchable and maintainable.
-John
John Passiak
(3,708 Views)
