Delphi support in NIDAQ 7.3
Does anyone have an example of delphi wrapper unit
to use NIDAQ 7.3 ?
It seems like NIDAQ doesn't support Delphi
as a language interface in this version...
Peter.
Message 1 of 8
(4,202 Views)
Nope - NI no longer supports Delphi. I'm in the same predicament. As I see it you have 3 choices:
1) Rewrite your stuff in Visual C/C++ or one of the other supported languages
2) Write a wrappper DLL in VC that you can call from your Delphi app. The VC dll makes the calls into NI-DAQmx.
3) Cobble up a Delphi unit using the NIDAQmx ".H" files, and call into the MX dll directly.
For our solution, I went with item #2 above. One of the main issues I ran across when calling the DLL from Delphi is that the FPU (in an X86 environment) must be setup differently than the Delphi normal case. When calling a DAQmx function from Delphi (either directly or indirectly through a wrapper DLL) you should do something similar to the following:
asm
finit;
wait;
end;
... call your DAQmx() function here...
Set8087CW(default8087CW);
I hope this helps,
-bill
Message 2 of 8
(4,196 Views)
and send a massage to your favorit NI-Dealer that want delphi support
What stephen perfers:
var Saved8087CW: Word;
Set8087CW($133f); { Disable all fpu exceptions }
{ do Set8087CW(Saved8087CW); to restore }
Message 3 of 8
(4,188 Views)
Could you please give me your wrapper DLL
written in VC and corresponding Delphi unit?
Why don't they (NI) make it public?
Message 4 of 8
(4,182 Views)
We are having the same problem with our new DAQ cards.
Can anyone put a example of a delphi wrapper unit online?
p.s. if there is anyone that has more information/solutions
about this problem could u please reply or contact me:
Manuel Bilgic
m-bilgic@ti.com
Message 5 of 8
(4,163 Views)
I would like to buy 2 M-cards (additional to my 6 E-series cards running on delphi 7 and traditional nidaq32).
I am only interested in changing to DAQMX, but up to now I am only looking for a solution in the board.
Parus, Stephen [sparus@umich.edu] made a delphi program with direct access to the dll. Maybe you contact him.
Ulrich
Message 6 of 8
(4,146 Views)
Hello!
Unfortunately, we haven't created a wrapper here at NI that makes NI-DAQ calls from Borland Delphi. If we would have done it, we would have posted it already. I have forwared this to R&D, so hopefully we should be seeing a wrapper soon. I know that customers have been successful in doing this before though, and they have ran into the floating point issue specified in the following KB:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/a6715aa42405acd786256f0a00633b8f?OpenDocument
Besides that, I will let you all know as soon as we have this wrapper.
LA
P.S: Ulrich_VII, what M-series boards are you interested in buying?
Message 7 of 8
(4,134 Views)
PCI 6224 M
I need up to 32 AD channels and 6031/33 are relativ expensive
Ulrich
Message 8 of 8
(4,095 Views)
