‎04-29-2010 03:59 PM
‎04-30-2010 02:25 AM
‎04-30-2010 10:54 AM
Hi aeastet,
There is no reports on my side of this happening to our customers. I can verify that the Description tab in custom scales still exists in MAX version 4.6.2. I would suggest reinstalling one of your hardware drivers (if you have a corrupted install of MAX 4.6.1) or upgrading to a newer hardware driver (to obtain MAX 4.6.2). MAX is included with driver packages, for example our DAQmx driver.
‎05-03-2010 11:27 AM
Hi aeastet,
Can I get more information from you regarding what you are seeing in MAX 4.6.1? How do you normally enter a description for your sensors? Are you trying to export your database from your previous MAX to this one? If you can provide an export file of your MAX configuration, that would help troubleshooting here. Let me know, thank you.
‎05-03-2010 11:59 AM
In 4.6.1 I see the decription tab when I go to a scale. When I moved that scale or opened it on another computer running 4.6.2f. I see the tab momentarily then the tab goes away. I can no longer programmicly access the information that I used to stor in the scale decription.
I am using the VI and property nodes that can with LabVIEW to access this information just like I have beeen doing since LabView6i. This is a very recent thing where I no longer am able to access this information.
I am currently working on a replacement of this anyway. I have grown tired of the changes that constanly happen in MAX that will break my code every time I upgrade. This was just the last push to get me to fix this the right way. I guess that is what I get for letting LabVIEW (National Instruments) handle my important information. Thanks for the help but I will fix this my own way and move away from anything other than a name in MAX.
‎05-03-2010 05:29 PM
‎05-04-2010 06:35 AM
I have been meaning to move out of NIMAX for years. I have someone working on a more perminenant solution already. I am not going to spend anymore time trying to figure out why. I am just going to move ahead with a better solution for me.
Thanks for the help.
‎09-18-2015 07:24 AM
We experienced this same issue a lot about two years ago and were told to update NI-MAX, which we did. The problem appeared to be solved (or at least go away), but it has turned up again in NI-MAX 14.5 ... is there a resolution for this? I had provided a lot of information to NI support about it but did not hear anything.
‎09-21-2015 04:58 PM
Hi Rick_J.
We are sorry for the inconveniences, I found a couple of Service Requests that I think might be yours describing this issue. I have not found other customers with this same issue in recent Service Requests, so I would like to know if this is something that you have seen consistently in the same computer or if this is something you have found in different systems.
Versions of OS and other software involved like the driver would be useful as well. Have you noticed if this is triggered by something in particular?
All the information you can provide would be useful to understand this behavior.
WenR
Applications Engineering
