02-22-2024 07:35 AM
Dear NI team..
I felt lucky to receive USB-6225, USB-6218 & NIDAQ930f2 software from my beloved senior but i was not completely sure about how to use those 2 devices and software..
those devices are purchased almost 10 years back, only those 2 devices i just have right now & not even required cables left..
i used a type-B cable with USB-6218 device and performed few test operations using the above mentioned software.. which are signal generation and logic analysation worked perfectly apart from that i don't know what to do with them but i'm feeling very excitement to take complete control over those 2 devices..
So,I need some help which are mentioned in the below points..
Thanks and Regards,
Dinesh B
Solved! Go to Solution.
02-23-2024 07:23 PM
1. See 62xx Models : DAQ Multifunction I/O Cable and Accessory Compatibility
2. NI-DAQ is obsoleted. You should use NI-DAQmx driver instead. See Getting Started with NI-DAQmx
3. It depends if you want to synchronize them. If synchronization is not needed, you can run two different programs or applications. If synchronization is needed, you would need to route and configure the timing signals. See Timing and Synchronization Features of NI-DAQmx
02-26-2024 05:50 AM
Thanks for the info @ZYOng, also may i know the complete setup image or any tutorial of USB 6225 i just wanna make sure how i should make the connections and test signal generation with USB 6225
02-28-2024 06:49 PM
I think this is the closest one
Archivé : Initiation à NI-DAQmx pour les périphériques USB
