Details regarding NI USB-6225, USB-6218 & NIDAQ930f2
Dear NI team..
I felt lucky to receive USB-6225, USB-6218 & NIDAQ930f2 software from my beloved senior but i was not completely sure about how to use those 2 devices and software..
those devices are purchased almost 10 years back, only those 2 devices i just have right now & not even required cables left..
i used a type-B cable with USB-6218 device and performed few test operations using the above mentioned software.. which are signal generation and logic analysation worked perfectly apart from that i don't know what to do with them but i'm feeling very excitement to take complete control over those 2 devices..
So,I need some help which are mentioned in the below points..
  1. Please share what are all the required Cables, Adapters what does the complete kit consists so that will try to purchase..
  2. Please share all the documents & tutorials related to USB-6225, USB-6218 & NIDAQ930f2 software (I found few.. but i'm not sure that i'm having a right one..)
  3. will USB-6225 can be configured with USB-6218 ?? if possible please share how USB-6225 will be used and how it can be configured with USB-6218 device..
Thanks and Regards,
Dinesh B
(730 Views)
Accepted by topic author Dinesh_Bylu
1. See 62xx Models : DAQ Multifunction I/O Cable and Accessory Compatibility
2. NI-DAQ is obsoleted. You should use NI-DAQmx driver instead. See Getting Started with NI-DAQmx
3. It depends if you want to synchronize them. If synchronization is not needed, you can run two different programs or applications. If synchronization is needed, you would need to route and configure the timing signals. See Timing and Synchronization Features of NI-DAQmx
https://tmesystems.net/
(676 Views)
Thanks for the info @ZYOng, also may i know the complete setup image or any tutorial of USB 6225 i just wanna make sure how i should make the connections and test signal generation with USB 6225
(640 Views)
I think this is the closest one
Archivé : Initiation à NI-DAQmx pour les périphériques USB
(599 Views)
