Dev1 needed for some DAQmx parameters but /Dev1 for others
Some DAQmx VI's such as Create Channel use Dev to specify their input parameter while others such as Digital Start Trigger Source or Sample Clock Source require a leading "/" as in /Dev1.  Is this done intentionally because they are different terminal types ?
(2,815 Views)
Hello Steve,
The main difference here is the difference between "physical channels" and "terminals".  A physical channel is defined without the backslash and can usually be specified in ranges (e.g. "Dev1/ai0:8").  A terminal is a single physical location is and defined by an absolute references to that location (e.g. "/Dev1/ai/SampleClock")  A good explanation of the difference is in the NI-DAQmx at the following locations:
NI-DAQmx Key Concepts » Channels and Tasks in NI-DAQmx » Channels, Physical Versus Virtual » Physical Channel Syntax
and
NI-DAQmx Key Concepts » Terminals » Terminal Names » Syntax for Terminal Names
Hope this clarifies.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(2,806 Views)
