Multifunction DAQ
Device visible in MAX but not in VISA
Hello All !
I am trying the get NI USB 6361 running. It is visible under Device Monitor and in MAX. No Errors are diplayed. I even was able to get it to work (set 10V to analog_out1) via the Device Monitor/testpanel.
Anyway i fail to get a connection via VISA. The error message reads something like "device not present in the system"
Drivers were installed automaticly after Connection of the USB device, do i need different Drivers for VISA?
I am thankful for any suggestion on how to solve this
VISA Nr of Implimentation 17.0
VISA Nr of Specification 5.7
MAX Ver17.0
LabVIEW 2017
Windows 10 Version 1703
(2,828 Views)
Accepted by GL_HEI
The USB-63xx series uses the NI-DAQmx driver API, not VISA.
(2,812 Views)
