 Paul_Knight_Loc
			Paul_Knight_Loc06-16-2016 10:36 AM
I have multiple cRIO-9081. Each cRIO-9081 is running NI-DAQmx 15.5. On four of the cRIO-9018 we have attached cDAQ-9178s with 8 modules. Everything just worked. On the fifth cRIO-9018 we attempted to connect a cDAQ-9174. The device showed up in MAX and Windows Device Manager, but MAX reported that the device was not present (Error -88705) and that Windows did not find a driver for the instrument.
We then plugged in a cDAQ-9178 into the fifth cRIO and everything just worked.
What is the difference between a cDAQ-9174 and a cDAQ-9178 other than the number of module supported?
Paul
Solved! Go to Solution.
 sunaenae
			sunaenae
		06-17-2016
		06:17 PM
 - last edited on
		02-10-2025
		02:13 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Paul,
In terms of specifications, the two cDAQ chassis should have almost exactly the same specs (at least in all the ways that would affect that connection) -- the only main difference is the number of modules, as you mentioned. More detail on the specs can be found here:
https://www.ni.com/docs/en-US/bundle/cdaq-9174-specs/page/specs.html
https://www.ni.com/en-us/shop/model/cdaq-9178.html
It looks like something may be wrong with your 9174 -- is it working when connected to another system? These are also some great troubleshooting steps to start with: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7OaSAK&l=en-US
06-19-2016 08:18 AM
Sunayna,
Yes the 9174 works with other computers.
Paul
 sunaenae
			sunaenae
		06-21-2016
		04:38 PM
 - last edited on
		02-10-2025
		02:14 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Paul,
This seems like it may be a driver issue! What version of DAQmx do you have installed on both computers? A reinstall of the newest version might be worth a shot since it looks like there may be some corruption. You can find the newest version here: https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288248
You can also manually associate the driver with the device, here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NFGSA2&l=en-US
Are there any modules plugged into the cDAQ chassis?
Also, sometimes this can happen if you do not reboot your computer after installing NI-DAQmx. Rebooting your computer after installing the driver will allow you to reserve the device successfully. Here are a few other steps to try:
06-22-2016 07:25 AM
Sunayna,
Reloading NI-DAQmx 15.5 and resetting MAX configuration database fixed the issue.
Paul
