Digital IO line is stuck at 5V for both input and output.
After board was sent in for repair, digital IO line 1 will no longer go low. Whether in input or output mode, the line will always be ~5V. Is this something that could possibly be fixed in software or do I need to send the board back in for repair again.
(2,432 Views)
Hello;
That seems to be a physical damage on the board, therefore there is nothing you can do Softwarewise to go around that.
Regards
Filipe A.
(2,432 Views)
