Digital Trigger with PCI6025E
I'd like to acquire a digital byte after a digital trigger using PCI6025E board. I can't use Group Config vi because it returns me error 10007. I believe that's a problem with port list. Some one had made something like this? Witch port list it works with?
(2,459 Views)
Well, the 6025E board does do handshaking I/O. You could probably still use this trigger as your handshaking signal to latch the port. You should be able to find several shipping examples within LabVIEW that you can work off of. (Browse from under the Help menu.) Look at the examples in the 8255 library since those will work with that board as well.
Russell
http://www.ni.com/support
(2,459 Views)
