Hopefully this is a simple question. I have a PCI-6733 connected to a BNC-2110, and I want one of the digital lines to monitor a connection and light a LabView LED when there is a digital high signal. Simple, right? The problem is, I can't get any response from the port in either NI-DAQmx or LabView. If I open MAX and run the test panels, all the lines show a digital high when configured as inputs with nothing connected. If I switch a line to output, it goes to digital low. Then, if I give it +5V, it goes to digital high. Weird, but OK. If I go to the DAQ Assistant in Labview or create a NI-DAQmx task directly to measure a digital in, the line shows high even if nothing is connected. I get the same result regardless of what acquisition mode I use. Inverting the line changes it to low, but then nothing happens if I connect the +5V. This happens with more than one line, so I don't think the board is malfunctioning. Also, it will do digital output just fine. Am I just missing something?
Chandra
