02-27-2008 09:47 AM
02-28-2008 08:14 PM
I see that you already have tried steps list in KnowledgeBase (KB) 2L7CT85F, however I believe the KB linked below will be more helpful to resolve the port conflicts. I realize you are not using Labview or any GUI, but that you are using the NI-DAQmx driver, thus this KB should help.
AE KB 481BLOCW: Why does Safenet's Sentinel Protection Service Crash After Installing LabVIEW?
08-30-2010 08:30 AM
Hi guys,
Sorry to revive a two year old thread, but I'm having this exact issue and apparently don't have permissions to access the KB. Searching it doesn't turn up any results on the site, so any advice?
I know one option is to regedit so Logos doesn't use ports 6001 and 6002, but I'm not allowed to regedit on my work pc. Any software fixes I can do?
- Jeff
08-30-2010 09:40 AM
Hey Jeff-
I don't know much about this subject but happened by your thread anyway. This KB seems to supersede the one that Samantha linked previously. If you still have issues after reviewing that info then I'll have to defer to a member of the NI Support staff.
Hopefully this helps-
08-30-2010 09:43 AM
Hi Tom,
I actually just rebooted from trying that KB, and it solved my issue.
Thanks!
- Jeff
09-22-2010 02:03 PM
I am also having the same issue. I cannot install or run my SafeNet drivers while lktsrv is running as a service on my Windows 7 64-bit machine. SafeNet technical support says that they require port 6001 for their Sentinel products.
Examining the KB document referenced above, it looks like I might have the old Logos service running.
(1) How can I determine if the have the old Logos or new LogosXT service running? The details of the running service: "National Instruments Time Synchronization", Version:5.2.0
(2) Does this fix noted (Logos.ini) work with Windows 7 64-bit?
(3) Is there a way to change the ports that lktsrv uses?
Jeff
