Display analog data in a table after acquisition
I am acquiring data from nearly 12 analog channels using a single task at the rate of 100hz and trying to display it in a table. I have renamed all the channels according to their functions and also assigned them a hardware number. But the problem I face is that am not able to find out which data comes from a particular channel. The graph should look like the one similar to the table in MAX with a column extra for displaying the hardware number as  well and I have attached the image of it. As of now I have tried to display all Channels, their hardware number and values acquired sequentially in three separate columns. Though it seems fine, I would like to know if there is any option to find out from which channel a particular value was acquired in a task with a number of channels?
(2,855 Views)
Duplicate Post
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(2,847 Views)
