Display analog data in a table after acquisition
I am acquiring data from nearly 12 analog channels using a single task at the rate of 100hz and trying to display it in a table. I have renamed all the channels according to their functions and also assigned them a hardware number. But the problem I face is that am not able to find out which data comes from a particular channel. The graph should look like the one similar to the table in MAX with a column extra for displaying the hardware number as  well and I have attached the image of it. As of now I have tried to display all Channels, their hardware number and values acquired sequentially in three separate columns. Though it seems fine, I would like to know if there is any option to find out from which channel a particular value was acquired in a task with a number of channels?
(3,289 Views)
I have attached the code of whst I have done so far..
(3,285 Views)
Accepted by topic author Karthi_R
The shift register for the while loop where you are collecting your data should be a 2D array.  Then each colum will be designated to a channel.
(3,263 Views)
It worked.. Thanks 🙂
(3,260 Views)
