Do 32bit drivers for NIDAQ-mx exist that can work with the NI-9230?
We currently have an industrial computer that can connect to the NI-9230. This computer runs on an ARM32 architecture with a Debian OS, but we can theoretically change the OS since it is not OS-locked.
Do 32-bit drivers for NI-DAQmx exist on linux that can work with the NI-9230? As far as I am aware, I could only find the NI-DAQmx Base Download from NI. But even then I am not certain if that has the capability for the 9230.
If this can't work, are there any alternate approaches that could maybe make these devices work together? That would be appreciated as well.
Thank you.
(594 Views)
NI-DAQmx supports Linux Desktop but unfortunately only supports /x86 64-bit architecture.
Does the NI-DAQmx for Linux/Windows support ARM architecture?
https://tmesystems.net/
(543 Views)
Thank you for your answer.
What about NIDAQmx Base? Would that support the NI-9230? I see here it supports 32 bit architecture.
NI-DAQmx Base Download - NI
(528 Views)
No, all NI drivers require the CPU architecture to be x86 and not the ARM ones.
Santhosh
Soliton Technologies
(525 Views)
