Does NextWriteIsLast Actually Work?
I am performing some continuous buffered AO, and I want to end cleanly, with no errors, and I want to know when the samples that I have fed in are done generating. I tried to "DAQmx Wait until Done", but that doesn't seem to work, presumably since I am using Continuous Mode.
I have the Regeneration Mode property set to Do Not Allow Regeneration
I see this cool Property called: NextWriteIsLast (http://zone.ni.com/reference/en-XX/help/370469AA-01/daqmxprop/attr296c/)
It sounds like it's exactly what I need... except that when I use it I get Error -200452, the description of which is: "Specified property is not supported by the device or is not applicable to the task."
Is there a list of supported/not supported devices somewhere?
I am using a simulated PXI-7833 until I get access to a real one. Is the PXI-7833 not supported? Or does the simulation not support this?
I there another way to do what I am attempting?
Thanks for any insights.
(3,480 Views)
The main reason is that the PXI-7833 is a multifunction RIO board and it requires the NI-RIO driver. The function that you are attempting to use is from the DAQmx driver. Please take a look to the requirements for your board in the link below,
http://sine.ni.com/ds/app/doc/p/id/ds-98/lang/en
(3,457 Views)
I am sorry, I meant to say PXI-6733. I have been using the 7833R a lot lately, but I am using a (simulated) 6733 for this example.
(3,453 Views)
