How to read 2 individual digital input lines on DAQ?
New to Labview and NI tools in general.  I am trying to use 2 individual lines on Port 0 of a NI-PXIe 6363 to read and move to individual arrays ~3000 pieces of digital data.  The problem I continue to run into is that for whatever reason, my Labview program is taking the sum of Lines 0 & 1 and recording that into my array of data as opposed to the individual lines that I believe I have selected.  I have attached my labview module.
If I change the DAQmx Read selection over to a Digital 1D Wafeform, then I can see the 2 individual lines of data in the waveform, but I also see the sum as seen in my array in the digital waveform graph as well.  I have attached a screen shot showing my 2 lines of data in this mode.  I have also tried to use this data to extract and move to an array with no luck.
My end gold is to have 2 arrays of 3000 pieces of 1 & 0's that I an return to Test Stand.
Thanks in advance to the help.
(3,367 Views)
Hi TesterABC,
Try having one channel for each line. Then for the Read VI, try Single Channel, Multiple Samples, U32.
Humphrey H.
(3,345 Views)
I think you mean Multiple Channels, Single Sample.
GCentral
(3,342 Views)
