Does SignalExpress support USB-9211/15 & USB-6015/16 ?
(3,111 Views)
Hi gsa,
Here is a list of hardware which is supported:
- NI M Series and E Series DAQ (DAQmx only)
- NI High-Speed Digitizers
- NI Signal Generators
- NI Dynamic Signal Acquisition (DSA)
- NI Analog Output
- Third-party devices (*Requires downloading or creating a LabVIEW based user-defined step)
You see, that you must program a LV based user-defined step in SignalExpress if you want to use the USB boards.
Luca
Luca
(3,109 Views)
Actually, SignalExpress does work with the USB-6015/16. I have not personally tried it with the 9211/15 though. In general it works with any DAQmx compliant device (excluding DAQmx Base).
(3,106 Views)
The USB-9211/15 are currently only supported under DAQmx Base, so in order to use these devices with Signal Express, you would have to create a user defined step, as Luca mentioned.
I hope this helps!
gus....
(3,093 Views)
