Does the DAQmx version on target machine need to match the version of the DAQmx driver of the machine where the executable was developed?
I'm developing a software in Microsoft Visual C++, using a certain DAQmx version in my development machine to access DAQ USB-6218.
Then the software is deployed on several machines.
Is it necessary that the DAQmx version on target machines match with the one installed on developing machine?
(595 Views)
Accepted by PaoloS
It is often not *necessary* to have an exact version match, but it's probably a generally good practice in cases where there isn't a compelling reason *not* to.
-Kevin P
(570 Views)
