Does the NI-DAQ DLL support multi user usage?
I am currently developping several applications that will acces the card at the same time. Is it possible and does the DLL s have support for multi users.
(2,403 Views)
The answer is yes and no. If the different programs are accessing different functionality (ie, AI, AO, CTR), then yes. If they are both trying to access AI lines for example, even if they are different AI lines, then no. If you have a specific setup you are curious about, post here again.
(2,403 Views)
