Running analog outputs simultaneously 6070E card
Is it possible to run both analog output channels for the NI PXI-6070E? I tried to do so, implementing two separate waveforms for both analog output channels ao0, and ao1. I was able to get one output waveform but not the other.
(2,529 Views)
Yes it is possible. Can you tell me what programming environment you are using and any errors that you are receiving? Are you using NI-DAQmx or Traditional NI-DAQ? If you are using NI-DAQmx, are you using the DAQ Assistant or DAQmx VIs? With your responses, I can tailor my answers. Have a great day!
(2,529 Views)
