I'm using DAQ to recieve thermocouple voltage attacted to AMUX-64T. I found powerline voltage, 50 Hz, is added to the thermocouple voltage. I'd like to eliminate it by using low pass filter function of LabVIEW. I try to connect low pass filter to "AI Read AI" directly, but I can't. How can I use low pass fillter function to correctly filter the data from DAQ? What type of filter should I use? Should I multiply the data before filtering? I need to see any example involed, if you can. I've attached "My VI.vi" file already. I would like to know where I should add LP filter. If you want any more detail, you can mail to me.
